Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Condensation and Evaporation modelling in Single Heat Exchanger
Old   July 14, 2015, 06:24
Post Condensation and Evaporation modelling in Single Heat Exchanger
somnath
Somnath rangrej is on a distinguished road
I am doing project on "Simulation and Analysis of multiple (3) effect evaporators (2 phase) in Process Industry", in which I want to model two phase flow in Evaporator.
Evaporator is of shell and Tube type, in which hot steam is flowing through the shell and cold water is flowing through the Tubes.
So in the single Heat Exchanger device, Shell side condensation and Tube side evaporation have to be modeled.
How it can be done?
Which model will give good results?
Any tutorial/lecture/theory which will help me to model?
Thanks.
Somnath rangrej is offline   Reply With Quote
Old   August 14, 2015, 06:53
Jim
CFDYourself is on a distinguished road
Hi Sonnath,
Ansys have some tutorials on heat exchange and two phase flow, so I reccomed contacting ansys support or the ansys customer portal as a first port-of-call.
There are really two parts to your question, and us here can't really tell you the best way to build your model.
one is how do you model heat exchange,
the other is how do you model phase changes in fluent.
off the top of my head, two things that might be useful to you are:
- Fluent's Macro Heat Exchanger model,
- Fluent's Evaporation-Condensation model.
but it's highly application specific, and its possible that a completely different approach would be useful in your model (eg: you might want to set a T-profile using UDFs. if you're interested in mass-transfer, or falling films, the evaporation-condensation model might be useless, etc. etc. etc.).
CFDYourself is offline   Reply With Quote
multiphase model
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
