Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF model
Old   July 2, 2015, 09:14
Post VOF model
Piyush Aras
piyusharas is on a distinguished road
I am working on a multiphase model .
It consist of a tank with a velocity inlet and 6 pressure outlets.
I have used V.O.F model
I want to find mass flow rates in 6 outlets is steady state.
I asked this doubt before and someone said that vof model do not converge in steady state so now I am using finding in transient condition.
everything is almost done but my solution is still not converging and also there are reversed flow at my all outlets. To this doubt everywhere its posted that extend the outlet . Can someone tell me what does it mean.
piyusharas is offline   Reply With Quote
Old   July 5, 2015, 22:58
hwet is on a distinguished road
It is normal to have reversed flow.
If you draw a vector plot on a plane inside your geometry you will see at the outlet some vectors pointing backwards into the flow domain.
If you have an extended outlet then this reverse flow will not cause any difficulty in convergence in cases it is not supposed to occur, the flow field has enough space to "steady out".
But it is turbulence modeling, when the solver solves the equations there is a fluctuating pressure field inside the domain, (since flow is turbulent), so at times it has a lower pressure inside the domain and high pressure at the outlet which can cause reverse flow. (just an example)
If you extend the geometry and still have reversed flow dont worry about it. Imagine even in the physical world if flow is concentrated on one part of the outlet it is possible that some fluid (very tiny bit) flows back frm the other end of the outlet.
And this is my personal research on the topic cant guarantee if i am right or wrong. Hope i make sense
hwet is offline   Reply With Quote
Old   July 6, 2015, 02:17
Piyush Aras
I am confused whther to use turbulance model or not.
Can you please help me out with it.
And when I use turbulance model what are values if parameters which I will have to give in the model.
Old   July 6, 2015, 23:21
It depends on your conditions, i cant just tell if all i know is there is an inlet and a few outlets to use a turbulence model or not.
But, well most real world flows are turbulent in nature...
Mixture model + VOF? blacksoil2012 Fluent Multiphase 2 February 9, 2014 00:59
VOF Model or Mixture Model mems21 FLUENT 2 March 9, 2010 11:37
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
help needed for vof model yan FLUENT 3 December 16, 2005 02:17
