Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Droplet particle collision
Old   June 22, 2015, 15:44
Question Droplet particle collision
Hossein1 is on a distinguished road
Hello friends,
I need to model a collision between a solid particle and a falling droplet. Based on existing experimental results after collision, particle start penetrating into droplet and create a very thin liquid film in shape of a hallow truncated cone around particle which is called lamella (whole the collision and lamella formation happens very fast ~ 1 ms)
My alternative softwares for simulation are Fluent, OpenFoam, Comsol and Gerris. I'd like to get a piece of advice from you to know which of these softwares is more suitable for simulating this phenomenon (i.e. is able to predict lamella formation and its geometry more accurately)
Here is some complementary information:
- Droplet diameter is 2.8 mm and particle diameter is 2.0 mm
- Droplet is falling by gravity and its velocity at collision is 0.8 m/s
- Particle is moving horizontally with 8.0 m/s
- Drop is water and particle density is 1050 kg/m3
I'm looking forward to hearing your helpful comments.
Many thanks,
Hossein1 is offline   Reply With Quote
Old   August 17, 2015, 09:29
Daniel José de Oliveira Ferreira
chaada is on a distinguished road
Hossein,
Maybe you could try use DPM ou DDPM particles for both solid and water droplets and turn on the options Collision and Coalescence in the Physical models window.
chaada is offline   Reply With Quote
collision, droplet, particle
droplet separation off a particle in turbulent stream anonymous_89 Main CFD Forum 0 August 22, 2013 14:40
injection problem Mark New FLUENT 0 August 4, 2013 02:30
problem with compilation udf about droplet collision (DPM) Jaskull Fluent UDF and Scheme Programming 0 November 7, 2011 15:09
droplet collision in KIVA, stretching collision and reflexive collision. Mori-Nik Main CFD Forum 0 March 15, 2011 12:07
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
