Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Three-phase Slug Flow modelling
Old   June 12, 2015, 08:18
Question Three-phase Slug Flow modelling
Yuki
YukiW is on a distinguished road
Hi all,
I am doing the simulation of the three-phase slug simulation for my research project. I have some problems about it, the main one is that I can't develop slug with the conditions used in the experiment.
Following are my simulation conditions:
Mesh: 6000mm*78mm (I tried 2D first)
Three inlets for air/oil/water on the left.
2D ,planar? Unsteady, 1st-Order Implicit Standard k-epsilon turbulence model Standard Wall Functions
surface tension: oil-water 0.03
boundary conditions:
air/oil/water inlets: velocity inlet, Vair=4m/s Voil=Vwater=0.5m/s
pressure outlet. 0Pa
wall:no-slip
initialization : Vair=4m/s Voil=Vwater=0.5m/s, air takes up the up half of the pipe, liquid takes the another half. Water cut= 0.4 liquid hold up. Stratified flow at the beginning.
The case runs about 10s with no other problems, but I can't get any slug in the pipe, only very small waves near the inlet, so I would say the flow remains stratified no matter how I change the velocities.
My opinion is maybe I should change planar into other 2D space but I dont know which one is suitable.
Could you please help me? Many thanks.
Yuki
YukiW is offline   Reply With Quote
conditions, multiphase flow, slug flow, vof model
Difference in flow distribution of single phase and multiphase analysis shivasluzz CFX 0 April 22, 2015 23:54
Modelling Slug Flow in ANSYS Fluent VOF. OliverMechEng2208 Fluent Multiphase 1 March 18, 2015 06:45
How to go about modeling injection nozzle two phase flow in FLUENT? skonda2 Fluent Multiphase 0 March 17, 2015 08:52
error message cuteapathy CFX 14 March 20, 2012 07:45
Single Phase Swirling Flow Modelling with Structured and Unstructured Fluent Daniel J. Suasnabar FLUENT 2 January 18, 2000 03:53
