May 13, 2015, 11:35 |
Solution method
michela cagna
Hi!
I simulate a multiphase flow that have three phases (two are fluid, the third is granular (solid)). My mesh, imported from meshing, is tetrahedral. My simulation describes the Rayleigh- Plateau phenomenon that occurs between the two fluid phases (water and oil). In other words, my geometry is reported in the attach and consists in a chamber with a inlet capillary where flow water with beads. This chamber has a lateral inlet where flows oil phase. When the water(plus beads) leave the capillary, it fails in a jet and meets oil and, thanks to Rayleigh-Plateau law, this jets is fractionated in drops. I simulate this problem using Eulerian model: first i used implicit method with second order upwind for momentum solution method and quick for volume fraction and with these methods simulations converged but I couldn't see the drops. Secondly i passed to explicit method with second order upwind for momentum solution method and geo-reconstructed for volume fraction, but my simulations diverged (for an higher courant number). So i reduced my time step till 1e-05 s but my simulations last too (127 days). I tried to change solution method for volume fraction: i passed from geo rec to compressive, but the situation is the same. Is it possible that Fluent had a size limit? I explain my doubt: I simulate beads those have diameter from 50 to 400 um. My mesh has element size of 115um. Is possible that Fluent has a limit about size of granular phase and element size of the mesh. The second question is: if i have a tetrahedral mesh, can i use QUICK solution method for volume fraction? Thanks all! Michela |
eulerian model, quick, solution method, tetrahedral mesh |
spatial discretization VOF, solution method | Ema40 | Fluent Multiphase | 0 | December 18, 2014 03:37 |
Solution of problem through Matrx Block Method | Naseem Ahmad | Main CFD Forum | 0 | August 17, 2012 05:10 |
Solution Method & turbulent intensity in CFX 5.5.1 | hamza albazzaz | CFX | 7 | June 29, 2011 12:39 |
water hammer solution by finite volume method | A.Maleki | Main CFD Forum | 1 | January 20, 2010 20:46 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
