Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem with plot of vapor volume fraction for each time step at a specific section
Old   April 25, 2015, 15:36
Default Problem with plot of vapor volume fraction for each time step at a specific section
Agnes
Walderdbeere is on a distinguished road
I have problems with plot of vapor volume fraction for each time step at a specific section.
I tried to make it using animation:
1. Active name/every 1/Time step -> Define
2. Animation sequence/PPM Image/Storage directory/XY Plot -> Edit
3. Node Values/Position on X Axis/Write to File/
Y-Axis Function/Phases…/Volume fraction/Phase-vapour/X-Axis Function-Direction Vector
Surfaces -> X-Coordinate-86.5
Write -> Select place and name of file
But in the generated file the values of vapour volume fraction were always 0, maybe its an average, because I expected really small values.
I tried with Plots -> Plot XY -> ... -> and i wrote a new file. The new file has already various values of vapour volume fraction (not 0, but small, such I expected).
But I was surprised, because I made 70 time steps and I achieved only 28 results (both for the first and the second method).
What make I wrong? Where is a mistake in my procedure?
Walderdbeere is offline   Reply With Quote
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 05:35
