Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
subcritical water flow with a waterfall at the outlet
Old   April 21, 2015, 07:17
Default subcritical water flow with a waterfall at the outlet
Ema40 is on a distinguished road
Hi everybody.
I am simulating an open channel flow, subcritical flow. At the outlet the flow has an atmospheric pressure, since it ends with a waterfall in a tank (the tank has not been simulated, so the outlet is where the channel ends). Have I to specify the gauge pressure=atmospheric pressure and stop, or also the water depth?
Thanks
By
Ema40 is offline   Reply With Quote
Old   April 23, 2015, 22:00
why? is on a distinguished road
What do you mean? I suppose if it is atmospheric pressure it should stay 0 Pa gauge pressure at the outlet.
Actually the difference in the pressures of the inlet and outlet should be what you expect the pressure fall/rise to be between the inlet and outlet just to give good starting point to the solver.
So the result with pressure at inlet 40 Pa and outlet 0, and another simulation result with inlet 80 Pa and outlet 40 Pa, will I think be the same.
That is what I think, cant guarantee if what I am saying is right.
why? is offline   Reply With Quote
Old   April 24, 2015, 16:41
Hi.
Thank you for your response!
multiphase flow, open channel flow, outlet boundary condition, subcritical flow, waterfall
Pressure outlet as a function of the flow rate (windkessel) Trev0r CFX 10 October 23, 2023 17:50
CFX CHT increased mass flow rate for water matters little for outlet air temperature dingsheng1206 CFX 7 December 4, 2013 21:04
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Problems with BCs in muliphase flow with water falling from a reservoir Paul_l FLUENT 2 March 11, 2011 05:59
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 08:32
