Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Droplet breakup
Old   April 20, 2015, 03:56
Default Droplet breakup
why? is on a distinguished road
If i turn the droplet breakup model on my water droplets, they get deleted for some reason. This doesnt happen though when the breakup model is off.
The Message is:
Injecting 100 particles parcels with mass x at t= y.
Number tracked=100 escaped=0 , aborted=0 trapped=0 _______
Deleted 100 particles
Then it continues with the iterations without the particles.
Any ideas?
why? is offline   Reply With Quote
Old   April 29, 2015, 07:28
Paritosh Vasava
vasava will become famous soon enough
Are you able to see any particle tracks? If they are leading to the outlet, it is possible that they are 'lost' through outlet.
vasava is offline   Reply With Quote
Old   April 29, 2015, 20:38
No, they are just deleted at the inlet, not 'escaped' or 'captured'.
If i turn the breakup model off then the simulation continues with tracking the particles into the volume from the inlet and going all the way to the outlet.
Turning it on though results in them getting''deleted''.
Cheers
Old   April 30, 2015, 02:20
Paritosh Vasava
Ok. Sorry but I may have mixed up 'escaped', 'deleted' etc. Anyways, it is possible that when you use droplet breakup model there may be additional input required. Have you noticed any changes in the injection properties tabs when you switch droplet breakup model on and off?
help me to simulate droplet breakup in T-junction toufik08 Fluent Multiphase 4 September 1, 2022 23:01
Switching between droplet breakup laws hwet Fluent UDF and Scheme Programming 0 April 10, 2015 03:18
KHRT, Droplet Breakup Vinod Dhiman FLUENT 0 September 24, 2007 05:38
Droplet breakup in external Flow Jason FLUENT 0 March 31, 2006 03:53
droplet breakup modelling Birute Main CFD Forum 0 August 5, 2003 08:39
