Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Partially premixed combustion - model: less/ no temperature rise
Old   April 16, 2015, 16:21
Default Partially premixed combustion - model: less/ no temperature rise
sanjeet Limbu
sanjeetlimbu is on a distinguished road
I am using the ignition delay model for combustion by compression stroke of cylinder... simulation to rapid compression machine. The mixture fuel is inside the cylinder compressed at 30 millisec.
I am able to run the dynamic mesh using the chem kin file for combustion . I got some results...
But I expected the combustion to make temperature rise, but i am getting early rise in temperature, while fuel also dispense early than compression end
If possible can u suggest if I entered any wrong input in initialization or model dialog box
The dynamic mesh used to show compression- for 30 millisec and combustion is expected after 30 millisec
Problem-
Everything related to combustion seem start early before compression stroke end.
Unable to get temperature/pressure rise after compression stroke at 30 ms
The mole fraction for n-heptane start from 0.0025, instead of the 0.00562 I entered in boundary condition for the model.
Please suggest how to set up the model as pressure and very low CFD post results
sanjeetlimbu is offline   Reply With Quote
Old   April 16, 2015, 22:17
sanjeet Limbu
I am using N2/O2/nC7H16: 89.5/10.307/0.00562 as fuel mixture
I am getting early combustion - seeing P and T graph from CFD post
Old   April 17, 2015, 00:50
sanjeet Limbu
I checked by change in initialisation mean mixture fraction 0 and 1, so for 298K as initial temp the mean mixture fraction is needed as zero, if I enter mean mixture fraction as 1- the temperature jumps to the PDF calculated 1100K.
Since the fuel mixture become nil if I use the mean mixture fraction as zero
Pl help how to keep both temp also 298 K and fuel mixture as entered in boundary condition PDF calculation
Old   April 18, 2015, 12:35
sanjeet Limbu
Dear frds
I am unable to get the Pressure and temperature rise after the compression end s at 30ms.
The fuel is getting destroyed all together after the first stage but it do not result in tempeartture rise after that.
I also donot understand the rise in fuel mole fraction till the compression stroke ends!! and later though it reducess
Can u suggest possible changes needed to make it reflect changes in pressure and temp post compression combustion
File Type: jpg fuel mole fraction and reaction progress.jpg (28.9 KB, 5 views)
Old   April 18, 2015, 22:04
sanjeet Limbu
Plesae someone reply to solve my issue, I am waiting ... my project is in trouble....
1. Pressure not rising during the compression stroke
2. tremperature not rising till 30ms and getting raised at instantly- abrupt
3. No combustion happening after it gets to 700K+ temp
Old   April 21, 2015, 21:13
Unhappy
sanjeet Limbu
Please help ... anyone... I am in trouble
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 11:40
premixed combustion using Zimont model bob FLUENT 12 January 9, 2017 14:02
Non premixed combustion model NiBa FLUENT 0 January 22, 2015 11:31
stoichiometry partially premixed combustion yorelchr Main CFD Forum 0 March 18, 2012 17:41
Turbulent premixed combustion error... XiFoam model achinta OpenFOAM 1 June 23, 2010 06:45
