Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Gas- Solid reaction modelling
Old   April 14, 2015, 17:30
Default Gas- Solid reaction modelling
Ranjha
qasimranjha is on a distinguished road
Hi, Am new user to Fluent. I want to simulate a packed bed reactor of simple rectangular cross section. Solid inside the reactor (CaO) is porous and gas (Steam) enter the reactor from above. Product of the reaction is calcium hydroxide(solid). The reaction is exothermic and the heat generated is transferred to fluid (HTF) flowing outside along the walls of the bed.
I have attached the geometry of the reactor.
I need to know if it is possible to simulate this reaction using Ansys Fluent. If yes then which models/procedure should be used. Is there any tutorial available for this kind of reaction in fluent?
Thanks
qasimranjha is offline   Reply With Quote
Old   January 13, 2020, 08:09
Kartik Jain
kartik297 is on a distinguished road
Hello.
Did you get any help on this? I need help for similar kind of simulation in FLUENT
kartik297 is offline   Reply With Quote
fluent, gas-solid reaction, heat transfer
simulating gas solid flow in circulating fluidized bed with different gas velocity dairry_s FLUENT 0 November 20, 2012 04:10
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Multicomponent Multiphase Reaction Modelling Anirban CFX 0 April 17, 2006 09:51
gas solid flow in a pipe Pandu CFX 0 July 30, 2001 17:53
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
