To put fuel mixture initialy for closed vessel combustion |
March 27, 2015, 17:55 |
sanjeet Limbu
Rep Power: 11 |
I am using the partially premixed combustion - ignition delay model, I have uploaded the chemkin file already for species 43. the fuel and oxidser composition is defined and I generated the PDF for the species mixture.
To check the Rapid compression model- that is the compression stroke for engine, I need the fuel and mixture to compress as simulated in experiment I am not able to define fuel for the control volume in boundary condition, as I will not do inlet that make fuel enters volume. But at start point the volume must contain the fuel mixture, as it closed system. The Fuel mixture area shown in figure will be , a cellzone - which i defines as fluid which has material name = pdf mixture I will be great help Last edited by sanjeetlimbu; March 29, 2015 at 15:44. |
Mixture fraction for combustion problem | Jonathan Lemay | CFX | 3 | November 5, 2007 15:57 |
liquid fuel combustion | camby | CFX | 0 | April 26, 2007 22:32 |
2 solid fuel combustion | giant | Main CFD Forum | 0 | May 24, 2005 07:46 |
Spray and combustion model for alternative fuel | Torn | Main CFD Forum | 3 | November 12, 2003 05:05 |
combustion chamber for liquid fuel | Kirill | CFX | 1 | November 18, 2002 11:07 |
