Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to go about modeling injection nozzle two phase flow in FLUENT?
Old   March 17, 2015, 08:52
Default How to go about modeling injection nozzle two phase flow in FLUENT?
Shailesh Konda
skonda2 is on a distinguished road
I trying to model liquid atomization and primary breakup in a converging- diverging nozzle using FLUENT. The geometry is attached below. It is a cross flow of water on a high speed jet combustion vapor. To start with am trying to model a cold flow simulation of water- air, which would create a spray at the exit. From my initial research of the problem in hand, i have decided to use Euler-Lagrange model. Gas phase described in Eulerian frame of reference and liquid phase using DPM model of FLUENT. Weber number of the liquid phase is high. At the throat region, speed is sonic (Mach no = 1). I am not sure what sort of atomizer model ( plain orifice or effervescent or any other) should i use to describe the liquid flow. In most of the built in atomizer model, the flow of two phases are co- axial. However, in my problem it is cross- flow.
So the primary question is how should i inject my liquid phase in DPM model of FLUENT? I would like to use blob injection model, so the initial diameter is that of the nozzle diameter and then use KHRT model to study the primary break up. In my problem, am interested in the primary break up, that is the region where it form liquid sheets, film for the core liquid. My aim to study the regime before the droplet formation.
Any sort of input, ideas are appreciated and it would help immensely in getting a step closer to solve the problem.
skonda2 is offline   Reply With Quote
dpm fluent, injection model, two phase flow
phase change of water to water vapor by hot gas flow dhiraj.pachpande CFX 3 December 8, 2014 02:55
Modeling air flow in Al2O3 melt problem NTSbike FLUENT 0 August 19, 2014 14:32
Boundary condition of velocity and pressure at interface for air water pipe flow jignesh_thaker2007 OpenFOAM Running, Solving & CFD 7 June 19, 2014 11:12
Mass Flow rate in spray water modeling Behnam Ghadimi Main CFD Forum 0 June 8, 2013 16:48
Need help in Modeling of two phase flow in A vertical Pipe Shikha10 FLUENT 0 April 1, 2013 05:39
