Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Buoyancy force of second phase in Eulerian model
Old   March 7, 2015, 13:05
Default Buoyancy force of second phase in Eulerian model
amin.z's Avatar
Amin
amin.z is on a distinguished road
Hi friends
I wanna know in Eulerian multiphase model, how fluent calculates the buoyancy force of second phase!? is there any official document or equation to describe it?
amin.z is offline   Reply With Quote
Old   March 12, 2015, 06:59
`e`
`e` is on a distinguished road
I have checked the gravity/buoyancy force for the second phase using the Lagrangian reference frame (DPM), and Fluent's built-in code agrees with my UDF code.
Is there a particular reason you are concerned with how Fluent handles gravity/buoyancy? If you're unsure of the theory behind this force, check out this post on a physics forum.
`e` is offline   Reply With Quote
Old   March 12, 2015, 07:12
amin.z's Avatar
Amin
hi
thanks for your answer
I know about buoyancy force but the question is about fluent solving procedure!
Fluent solves only a few equations! no further things!
I want to know in Eulerian multiphase model, how fluent calculates the effect of buoyancy force? where is the buoyancy terms? only in momentum equations? or...
Old   March 12, 2015, 22:13
`e`
Yes, I know you were after the Eulerian model. I've only experience with the DPM but suspect Fluent has a similar approach for handling the gravity/buoyancy effects with their Eulerian model. You could turn gravity off and write a gravity/buoyancy source term UDF to handle these effects in your own way (or to check Fluent's implementation is correct, as I have done with the DPM).
Have you read the User Guide and Theory guide? There are a few sections on inclusion of gravity effects by the looks which might answer your question. Are you getting erroneous results with your second phase or what's happening?
Old   March 14, 2015, 02:51
amin.z's Avatar
Amin
I don't want write a UDF for my simple problem!
In fact, I've used Eulerian model and my problem has converged but my advisor has a doubt about calculation of bouyancy force by fluent. as you, his expert is in DPM.
and another question about phase interaction tabs! I' modelling a bubble column. the problem is in "turbulent dispersion" tab. my advisor suggest me to use "Lopez-de-bertodano" but in this condition, the solution is very unstable and finally lead to divergence! but by another model it's very stable and easily converge!
what's your opinion? do you know a reference to explain these models!?
Thanks
Old   March 14, 2015, 05:13
`e`
It would take perhaps five minutes to write and test the UDF to ensure the buoyancy/gravity calculations are correct. This task is not complicated or lengthy, it's simply a DEFINE_SOURCE macro.
I'm not familiar with these models but if one works then I'd go with that one. I recommend reading literature on these models because they appear very case specific (you might get lucky with an informed forum member replying though); best of luck!
Old   March 16, 2015, 09:14
amin.z's Avatar
Amin
Thanks
In fact, I would like to find out equations which solved by fluent
wall shear stress based on primary phase in eulerian multiphase model Abishek Fluent UDF and Scheme Programming 1 May 31, 2022 13:15
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
Lift coefficients for Eulerian Multiphase Model Anastasios Georgoulas FLUENT 0 July 14, 2008 07:13
Source Term used in Eulerian Model(Two phase) Padian FLUENT 1 May 19, 2008 04:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
