March 2, 2015, 17:53 |
Two Phase Flow Through an Impeller
Philip
ANSYS FLUENT:
I am currently trying to model a system in which a two phase (water and air[ Volume fraction 20%]) passes through an impeller. -Mixture Model -K-epsilon Turbulence Model -Rotating reference plane of impeller location at 100 rad /sec -Inlet velocity, water=0.6 m/s and air 0.5 m/s The problem that I am having however is that the solution is that the AMG is diverging. Any tips on creating a model for this system would be very much appreciated as I am no expert at CFD. Thanks. |
cfd, fluent, impeller, multi phase flow |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
No flow through periodic (cyclic) boundaries in impeller with foam-extend-3.1 | anttiad9000 | OpenFOAM Running, Solving & CFD | 3 | March 2, 2016 20:37 |
Two phase flow solid-fluid in river beds | Samchak | Main CFD Forum | 0 | May 23, 2013 09:44 |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 04:03 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 08:59 |
