February 25, 2015, 05:20 |
Problem regarding boiling in a tank
RAHUL B R
Hi freinds , I've a problem regarding the boiling of a cryogen in a tank in ANSYS FLUENT 13.0
Problem description in brief: A cylindrical Tank is inially filled with Liquid Nitrogen . A constant heat flux is given on the bottom side of the tank. On the top of the cylinder a small pipe is fixed for flow of gaseous nitrogen. I've used VOF multiphase, Standard K-epsilon model. During Calculation ,the problem arising is.. 1) Mass flow rate graphs showing a negative trend with respect to flow time( I need to find out the mass flow rate for a few seconds say 10sec) Eagerly waiting for a reply to the solution of this problem.. Rahul BR |
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 07:47 |
Flim Boiling Boiling | tsram90 | FLUENT | 3 | October 24, 2016 09:12 |
convergence problem of the SST and RNG k-e model for mixing tank | ziyan7 | FLUENT | 0 | March 8, 2011 06:13 |
Pressure BCs for rasInterFoam tank fillingdraining problem | kwardle | OpenFOAM Running, Solving & CFD | 8 | September 17, 2008 14:37 |
Mulitphase Problem | sam | FLUENT | 2 | July 3, 2003 10:54 |
