Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Wave Generation with Turbulence Models
Old   February 21, 2015, 07:13
Default Wave Generation with Turbulence Models
Ahmed Elhanfi
Ahmed Elhanafi is on a distinguished road
Hi All,
Id like to generate regular waves in Fluent. I successfully generated regular waves with laminar flow, but when tried to move to turbulent flow using either K-E or K_W and SST models, I got a problem with the results as you can see in the attachment.
Please, if you don’t mid helping me with this issue.
My Model Details are as follow:
Model details:
2-D model with 40m length 0.8m height and 0.5m water depth.
Free surface zone is 0.3m with 20 element/wave height and 100 element/wave length.
Mesh quality (Quad) 1.0.
I’m using open channel boundary conditions, Implicit solver.
Boundary conditions:
Left side: Inlet (open channel), Right side: no slip wall, bottom: no slip wall, top: outlet (open channel)
Solver settings:
Pressure-Velocity Coupling: PISO
Gradient: Least Squares Cell Based
Pressure: PRESTO! or Body Force Weighted
Momentum: Second order upwind
Volume Fraction: Compressive
For turbulence: Kinetic energy and dissipation: 1st and 2nd order upwind
Transient Formulation: Bounded 2nd order Implicit
Time step: 0.0025 sec.
No of Iterations: 20
Ahmed Elhanafi is offline   Reply With Quote
Old   May 14, 2015, 14:02
danielfc is on a distinguished road
I am using a very similar setup, but my wave is a irregular sea state imposed by an udf. By performing a mesh density study, I chose a mesh just like yours.
The only difference I can see is the boundary conditions. Are you interested in the effects of shallow water? Which is the wave amplitude? Since I am simulating a deep water scenario, I always use free slip on the bottom and top regions, as long as they are far enough from the fs zone.
danielfc is offline   Reply With Quote
variety of turbulence models in cfx? hamidciv CFX 5 January 4, 2016 03:41
Accuracy of Boundary Layers With Turbulence Models de5truction FLUENT 2 June 3, 2011 19:36
boundaryFoam, axisymmetry and turbulence models thomas_toulorge OpenFOAM Running, Solving & CFD 0 May 12, 2011 14:05
Y+ ranges for Turbulence models han toss Main CFD Forum 2 October 16, 2005 05:07
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 16:39
