February 13, 2015, 20:57 |
VOF with evaporation and condensation UDF's
G. S.
Rep Power: 15 |
Hello colleagues,
I have a question for those who know Fluent from its inside... The VOF model theory states that only mass conservation equation is solved for secondary phases, therefore they called them the volume fraction conservation equations....At the end the primary phase volume fraction is the unity less the sum of secondary phases mass fractions.... So if I implement UDF to model evaporation and condensation (for example: water) mass sources, why should I have to write UDF for both cond/evap mass sources for primary phase if it is going to be calculated after volume fractions of secondary phases are done... Best regards... |
February 16, 2015, 12:07 |
navid
Rep Power: 16 |
Can't you just use the evaporation-condensation option for mass transfer in the phase interaction toolbar instead of using a UDF?
When I use VOF, the evaporation-condensation option for mass transfer is available and can be used. I use Ansys Fluent 13. Maybe this option is not available in other versions of the software. |
February 20, 2015, 03:22 |
Khalid Baker
Rep Power: 17 |
Hello guys I have a question : is the evaporation-condensation option work properly with VOF model?
March 14, 2015, 19:37 |
G. S.
Rep Power: 15 |
Dear colleagues thanks for your answers....
I found this in the User's Guide...
Even if this is available or not, I'd like to consult the main question of my post which is what happens with the mass source calculated, by a UDF, for primary phases if no vof equation is solved for this one... Best regards...and again thanks for your answers.... |
March 15, 2015, 15:01 |
Khalid Baker
Rep Power: 17 |
Dear gerardosrez thanks for illustration. About your question if you not use vof model so what model of multiphase flow you tried? furthermore selecting which of the phases be primary or secondary that is your choice and you can set any of the phases as primary or secondary as you like? I think your question seems obvious something?
kbaker |
condensation, evaporation, mass source, udf, vof |
Evaporation & Condensation model | Amit | FLUENT | 0 | September 7, 2012 06:53 |
evaporation and condensation in Fluent | aximefu | FLUENT | 4 | May 12, 2012 09:47 |
Question:Considerations about the evaporation in VOF | dokeun | FLUENT | 10 | February 24, 2011 20:47 |
Water Evaporation and condensation modeling | Linjie | CFX | 6 | May 24, 2007 14:55 |
evaporation and condensation in the VOF model | Glev | FLUENT | 0 | December 24, 2004 04:55 |
