Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
open channel boundary condition
Old   January 27, 2015, 19:56
Default open channel boundary condition
pouyan
pa8001 is on a distinguished road
hello
I am trying to simulate openn channel flow 2D. I know the exact velocities at the inlet and the outlet. Can I impose constant velocities to the inlet and outlet during the transiant simulation? I dont want the velocity at the outlet change during the simulation.
Any suggestions would be greatly appreciated.
pa8001 is offline   Reply With Quote
Old   February 5, 2015, 14:07
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
What is transient about the simulation if your BC velocity is fixed?
edoan is offline   Reply With Quote
Old   February 8, 2015, 09:43
pouyan
thank you for answering!
I am trying to simulate a hydraulic jump just by imposing the depths of upstream and down stream.
acctually I want a uniform flow with a constant speed at time 0 and then the velocity at upstream BC increases to 5m/s but I want to keep downstream flow subciritical to have a hydraulic jump somewhere in between. but I dont know how to do so.
Old   April 18, 2015, 05:34
Ema40 is on a distinguished road
Hi. Try with these three ways:
Steady simulations:
1) fix both the water depths already at the beginning of the simulations and run the simulations up to the convergence (also try different initialization methods, both NONE and FLAT, which are initialization methods for open channel flow)
Unsteady simulation
2) as 1)
3) Fix only the upstream depth
Let me know if you success in this and the more appropriate solution!
Bye bye
Ema40 is offline   Reply With Quote
Old   April 20, 2015, 12:35
pouyan
Thank you ema!
What i did, is running the simulation in transient. I set the depth of downstream BC at the begining, but the model wont maintain it fix. In the other word, I want to tell the model to change the velocity not the depth! But it wont understand.
I want to know if there is any way to have a fix depth of water in the downstream in a transient simulatin? Because as i mentioned, i want to produce a hydraulic jump.
Any help would be greatly appreciated.
Old   April 20, 2015, 14:00
Hi...I don't know....probably the water depth that you set is wrong. Or maybe the changes that it undergoes are very small and they are only numerical oscillations..
But you fixed both the downstream and the upstream water depth?
Try fixing the mass flow at the outlet and the other methods that I said you..
Let me know
Bye
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
Condition of Air velocity in Open Channel simulation wes1204 OpenFOAM Running, Solving & CFD 0 May 9, 2014 06:08
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
Wave generation using open channel wave boundary condition krishnaprasad Main CFD Forum 0 March 3, 2011 22:28
open channel flow boundary conditions yan FLUENT 0 July 5, 2005 00:36
