Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
open channel flow BC pressure outlet
Old   January 17, 2015, 08:21
Default open channel flow BC pressure outlet
Ema40 is on a distinguished road
Hi everybody.
I am simulating a open channel flow with a water wheel. I have 3 outlet:
1) the first is where the water flow exit, with above the air
2) an other outlet where exit only air, since it is above the previous outlet
3) the third is lateral, above the wall which contains laterally the channel
In the boundary conditions I have to specify the bottom level (I chose the metod "from neighbour cells"), but since each outlet has a different bottom level, the only way to specify different bottom level is to define for each outlet a different outlet ID. But in this way Fluent doesn't start. Why? How can I do?
Thank you
Ema40 is offline   Reply With Quote
open channel, outlet, pressure outlet, water wheel
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
pressure outlet BC for incompressible flow khaiching Main CFD Forum 6 October 15, 2005 03:58
