Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fluent not patching in the right way
Old   December 6, 2014, 22:22
Default Fluent not patching in the right way
G. S.
gerardosrez is on a distinguished road
Hello Fluent users,
I am trying to patch the half volume of a 3d region....
I use the following strategy (as per tutorials)
1. Adapt-->Region-->Mark
2. Solution Initialization-->Initialize
3. Patch
I check the marked region and it is good, but when I plot a contour with the Volume fraction I see that all the volume has been patched with the value specified for the secondary phase (VOF model by the way)....
Have you had similar problem...
Best regards...
gerardosrez is offline   Reply With Quote
Old   January 19, 2015, 03:51
Default You may have patching problem.
Blue's Avatar
Blue is on a distinguished road
There are two options are available on patch window. First one is FLUID and another one is 'WHAT YOU HAVE PATCHED'. So select only one of them. Check your co-ordinates etc in ADAPT window.
Hope this will solve your problem.
Blue is offline   Reply With Quote
Old   February 13, 2015, 22:11
G. S.
THanks it solved my problem...
fluent, patch, vof, volume fraction
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
patch error OF v2.2.2 mac hewei OpenFOAM Installation 4 November 30, 2013 17:55
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 03:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
