Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Divergence in Two phase flow in impeller for Cavitation
Old   November 5, 2014, 05:39
Default Divergence in Two phase flow in impeller for Cavitation
Azarbayjan-e Sharqi (East Azerbaijan)
joshghoun is on a distinguished road
Hi Dear Friends
We are simulating the cavitation in an impeller, but unfortunately the solution diverges:
Do you have any recommendation
iter continuity x-velocity y-velocity z-velocity k epsilon vf-phase-2 time/iter
reversed flow in 184 faces on pressure-outlet 7.
1 1.0000e+00 2.2754e-01 2.0786e-03 2.2741e-01 1.6760e+02 1.7002e+03 0.0000e+00 48:34:52 9999
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2 cells
reversed flow in 135 faces on pressure-outlet 7.
2 3.9495e-01 2.1120e-01 5.1330e-02 2.0287e-01 3.4835e-01 1.0742e+00 0.0000e+00 52:44:50 9998
reversed flow in 136 faces on pressure-outlet 7.
3 4.8944e-01 1.9892e-01 7.2566e-02 1.8881e-01 2.4924e-01 7.2195e-01 0.0000e+00 52:44:45 9997
reversed flow in 158 faces on pressure-outlet 7.
4 4.1480e-01 1.1867e-01 5.1597e-02 1.2584e-01 1.3764e-01 2.6765e-01 0.0000e+00 53:17:57 9996
reversed flow in 163 faces on pressure-outlet 7.
5 4.4587e-01 1.2438e-01 6.2952e-02 1.2580e-01 1.0816e-01 2.0903e-01 0.0000e+00 53:11:07 9995
6 4.4594e-01 1.2414e-01 9.4380e-02 1.3768e-01 2.3518e-01 3.0147e-01 0.0000e+00 53:38:54 9994
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 11 cells
reversed flow in 162 faces on pressure-outlet 7.
7 7.3659e-01 1.0458e-01 1.5275e-01 9.0316e-02 2.9884e+01 8.1153e+02 4.9588e-04 49:34:35 9993
reversed flow in 180 faces on pressure-outlet 7.
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 198 cells
8 1.2326e+01 1.4642e-01 1.9726e-01 1.2146e-01 7.8176e+02 2.2140e+06 3.9421e-01 46:19:07 9992
reversed flow in 244 faces on pressure-outlet 7.
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 6369 cells
9 2.0270e+03 3.6374e-02 2.0211e-01 7.3595e-02 2.5758e+03 4.9818e+07 2.3196e-01 43:09:24 9991
# Divergence detected in AMG solver: k -> Increasing relaxation sweeps!
joshghoun is offline   Reply With Quote
Old   November 5, 2014, 09:10
Paritosh Vasava
vasava will become famous soon enough
There are several reasons for divergence of AMG solver. Your mesh is too coarse, time-step is too large, turbulence boundary conditions not specified correctly and so on.
Also you may want to look at the turbulent viscosity. Although it is very common to have the turbulent viscosity limited to viscosity ratio of 1.000000e+05 warning but if it is not disappearing by the iterations then it is a matter of concern. You can plot turbulent viscosity or viscosity ratio and see where it is high and refine mesh in that region.
vasava is offline   Reply With Quote
Old   November 5, 2014, 10:33
I am trying to model two phase of fluid in impeller the primary phase is water second is vapor water
Below is the last result that I got at the final iteration:
How should the vf-phase-2 progress in iteration?...
Thanks
AMG on GPGPU
11 7.7680e+04 5.7695e-02 9.2269e-02 9.3629e-02 3.7974e+01 2.8999e+05 9.3219e-02 25:42:53 9989
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Divergence in Two phase flow. black key Fluent Multiphase 0 October 25, 2014 02:01
Divergence - two phase flow narendra.gadwal Main CFD Forum 2 October 7, 2014 23:37
Two phase flow models Atholl Main CFD Forum 2 May 7, 2002 04:49
