Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
investigation of nanofluid in fluent
Old   October 31, 2014, 14:55
Default investigation of nanofluid in fluent
azi90 is on a distinguished road
hi,
I want to investigate the effect of the nanofluids on heat transfer enhancement in fluent by dpm. according to my channel size,it needs 10^17 nanoparticles for 1% volume fraction. in this method(dpm), it needs to determine mass rate of nanoparticles instead of the number of nanoparticles as input parameter in fluent. also, it needs to determine the injection surface of nanoparticles.It seems that flluent sets the number of particles using mass rate of nanoparticles.Now, when i determine the inlet surface with 400 nodes (400 streams for nanoparticles),the pressure difference between the inlet and outlet channel is significantly different with when i determine the inlet surface with 1000 nodes (1000 streams for nanoparticles).What is wrong?
thanks in advance
azi90 is offline   Reply With Quote
FLUENT Mixture model for Nanofluid Waqas Ahmed FLUENT 16 March 16, 2019 04:53
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 07:22
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 03:57
nanoFluid modeling in fluent hamid FLUENT 0 February 9, 2007 06:53
