Multiphase Eulerian simluation problem on Fluent 15.0 |
September 26, 2014, 22:59 |
Hoe Chen Hou
I simulating multiphase fluidized bed which included a simplified species transport. When any of the phase material choosen is under Mixture categories, there is a weird error pop when i try to initialize my solution. It shows Error: Received a Fatal Signal (Segmentation Error) which shown in the attachment in the post. Anyone come across with this problem before and would u mind to share how to solve the problem? Thanks in advance. Regard Hou Untitled.jpg |
December 19, 2014, 04:01 |
dear Hou
Hotice
I faced the same problem as you did.someone say it is the problem of the software-fluent.I don't know for sure.Did you solve the problem.I wanna get your help ,thank you very much.
Stefan problem using fluent | Isaacibp1401 | Fluent Multiphase | 2 | June 7, 2021 05:49 |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
Problem with compiling UDF in Fluent | amojodi | Fluent UDF and Scheme Programming | 4 | April 14, 2015 09:01 |
FLUENT 15.0 vs older version (worse convergence!) | SH_P | FLUENT | 0 | April 16, 2014 13:30 |
Can I use fluent to solve this multiphase problem | Steven | FLUENT | 1 | January 24, 2003 20:52 |
