Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
particle diameter
Old   September 25, 2014, 17:48
Default particle diameter
hamid_reza
hamid_reza is on a distinguished road
hi;
i want modeling multiphase flow with eulerian approach.
how to find value of particle diameter for secondray phase?
thanks for your answer.
hamid_reza is offline   Reply With Quote
Old   September 25, 2014, 21:44
Gbenga
noponus is on a distinguished road
I think your question is how to define the particle diameters in .
If am I right, you will define your particle diameter through the injection file.
The injection file is located discrete phase model (DPM)
let me know if I answered your question
noponus is offline   Reply With Quote
Old   September 29, 2014, 07:52
Cees Haringa
CeesH is on a distinguished road
If you use a single discrete phase size:
size = C_PHASE_DIAMETER(c,t);
gives the set diameter. For population balances, refer to the population balance manual.
edit: sorry, that is if you need to write a UDF and require the macro for that.
Otherwise, with eulerian mutliphase, you set the phase diameter in phases > secondary phase
CeesH is offline   Reply With Quote
Old   October 2, 2014, 13:29
hamid_reza
hi;
Monitor particle diameter and its frequency at a plane Lola27 STAR-CCM+ 1 December 19, 2013 06:33
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Averaged Sauter Mean Particle Diameter sjtusyc CFX 5 September 10, 2012 10:53
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 04:56
