zain
Rep Power: 12 ![]() |
hi ,
i'm trying to simulate airflow reactor using where the reactor are filled with water and air is injected in the almost middle of the column , here is my setting and problem description model>euler>implicit turbulence >k-epsilon>dispersed i tried many cases for interaction , also solvers but it keep giving me revers flow !! the boundary conditions for air ( dispersed phase ) u=0.6m/s (Secondary phase ) air volume fraction = 1 cause only air is injected no outlet in the system also i used marked to inject the air with (0 volume fraction in the cell zone) any suggestion plz what is the wrong with my setting ? which gives a reversed flow ?? |
Cees Haringa
Rep Power: 0 ![]() |
Dear Zain,
How exactly are you simulating a reactor that has an inlet but no outlets? That doesn't work, right? Where do you get the reversed flow? I guess for the air inlet your boundary condition is a velocity inlet - so I guess it is not there? Best, Cees |
zain
hi Cees
thanks for your reply the revers flow happened in few cells after entrance the reactor have only gas in and gas out and liquid are contained in the reactor i figure out my mistake it was with the turbulence model i used dispersed model for multiphase and that mean the turbulence will be in the secondary phase and partially in the primary phase while i should use mixture where the turbulence happen in both phases by this setting the effect of gas phase will make the liquid move in the right direction . thank you for your attention cheers ! |
euler, problem, reverse flow |
Problem using Central differencing scheme with LES WALE | selvam2487 | CFX | 8 | July 23, 2017 15:33 |
lax friedrich scheme for shock tube problem. | manukamin | Main CFD Forum | 3 | March 22, 2016 01:02 |
Accuracy problem of HO schemes on unstructured mesh, HO scheme gives 1st order result | gemini | Main CFD Forum | 12 | December 27, 2011 21:01 |
Lax-wendroff scheme for Shock tube problem. | manukamin | Main CFD Forum | 1 | November 26, 2011 14:10 |
Fundamental problem with Gamma scheme | dominik_christ | OpenFOAM Running, Solving & CFD | 3 | August 29, 2008 08:24 |
