Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Weird Velocity Field for Capillary Flow in a Horizontal Tube
Old   July 8, 2014, 20:23
Default Weird Velocity Field for Capillary Flow in a Horizontal Tube
yu feng
mashimaro_star is on a distinguished road
Dear All,
I am new to use VOF to simulate Transient capillary flow. I tried to setup a simple 2D case for a water capillary flow in a horizontal tube (no gravity). Here are some setups:
(1) The contact angle is 60 degree, and the surface tension coefficient is 0.04 N/m.
(2) The liquid is set as the second phase and the air is the primary phase. I patched a region near the pressure inlet being filled with liquid.
(3) The time step is 1e-5 sec.
The volume fraction result seems ok. But, there are two problems make me feel that there is something not correct for my case:
(1) The interface seems wavy (please see figure 1). Anybody has the same problem? is this normal? Or this is due to some numerical inaccuracy?
(2) The Y-velocity field is weird for me. It seems that my calculation is wrong based on the Y-velocity contour (please see figure 2). If you know how to correct this, please let me know. Thank you very much in advance!!!
Yu
mashimaro_star is offline   Reply With Quote
Old   December 15, 2014, 06:34
nurfatin
nurfatinas is on a distinguished road
I couldn't load the pictures you had attached somehow but based on your statement I seem to have the same problem as you (or maybe not). Had you possibly resolved the issue? If yes I really hope to hear from you.
The picture is as attached.
Thanks.
nurfatinas is offline   Reply With Quote
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
Flow Across Tube Banks - Transient vs Steady State HeatTransferFan CFX 11 September 28, 2012 15:21
Velocity of flow v time MitsubishiEvo6 FLUENT 0 August 31, 2012 00:51
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 17:28
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
