June 18, 2014, 05:39 |
Transient residual plot in Multiphase flow
Julez
Rep Power: 12 |
Dear all,
i have some problems to interpret my residual plot for a laminar transient simulation with the VOF Model. I have read that the initalization for multiphase flows has a big influence for the solution. Is this right? Can somebody give me some advice how to interpret right the transient residual plot? Thanks a lot! Greetings, cucko |
July 12, 2014, 11:18 |
Rick
Rep Power: 27 |
Hi Benjamin,
I think you have converged solutions for each time step: each residual goes up at the beginning of each time step, then rapidly decreases to convergence you set, or it becomes "flat" and oscillates a bit. Continuity residual is near 10^-3: you should verify if your solution is converged by monitoring some other variables (and by checking if mass balance is ok): if they don't change at the end of each time step you should have a converged solution. Daniele |
July 15, 2014, 07:01 |
Julez
Rep Power: 12 |
Hey Daniele,
thanks for your quick reply. I know that this "up and down" are iterations for each time step till a abort criterion. But i m doubtful because if u set the timestep size smaller your solution will congerve at first view. So the time-step size is a strong criterion. My Question is, how can i be sure that my simulation is physically correct? Set some monitoring points and view if they are changing for each time step? If they arent changing i should have a steady state problem or? It is hard for me to imagine congerving solution for transient cases. Thank you! Greetings, Ben |
July 15, 2014, 08:43 |
Rick
Rep Power: 27 |
Trust the results is up to you: however you can judge convergence by monitoring some variables (velocity, pressure, etc.) somewhere in your domain.
Solution is converged if those variables don't change at the end of each time step, before iterating to the next one: this can be a criterion to judge the convergence in the timestep. Obviously if the values of these variables don't change from one timestep to the next you have a steady state solution. Correct timestep size should be selected to make the solution to converge in 20-30 iterations, in each timestep. Daniele |
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
Courant-number explodes after a lon while (icoFoam) | Rody- | OpenFOAM Running, Solving & CFD | 6 | January 29, 2014 05:27 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 11:14 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 13:53 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
