Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
it is possible tu simulate water phase change with fluent 14 or 15?
Old   June 6, 2014, 05:23
Default is it possible to simulate water phase change with fluent 14 or 15?
azadehkhalili
kh91 is on a distinguished road
Hi everyone
i am modeling an annulus pipe with fluent that the internal wall of pipe has a constant heat flux. pipe is vertical and water is flowing upward through the annulus. by the heat of the wall, the water will have phase change and vapor will be create. is it possible to simulate this case with fluent? is it required to write udf for mass and momentum transfer? if the answer is yes what are the equations?
thanks in advanced.
kh91 is offline   Reply With Quote
Old   June 13, 2014, 09:58
Sandeep Siwach
sandeep.siwach is on a distinguished road
Hi, I am also working on getting a simulation working to see water change phase with heating. In my case, I can see the vapor volume fraction increase in the flow direction and liquid volume fraction to decrease in the flow direction. But, I am unable to activate mass transfer in the "Phases Interaction" toolbox. As soon as I turn the mass transfer on, the solver diverges within few iterations..... Have you been able to get a converged solution with mass transfer turned on. I am not using any UDFs at the moment.....
sandeep.siwach is offline   Reply With Quote
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
Fluent phase change problem dinesh Fluent Multiphase 6 April 5, 2018 18:47
phase change modeling Danial Q Main CFD Forum 0 April 5, 2012 02:14
phase change of a dispersed fluid Alex phillips CFX 1 October 23, 2006 15:40
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
