June 4, 2014, 12:29 |
problem with mass flow calculations
Eduardo Almeida
I'm using Fluent to simulate a fluidized bed where there is a lateral inlet of solids and two outlets, top and bottom.
My goal is to separate two distinct solid phases, one of them must be dragged to the upper exit and the other fall through the bottom. I'm using Eulerian model and as b.c. velocity inlet of solids and outlet pressure where the pressure differential between the outputs generates the air flow inside the riser. My problem is related to the mass flow in both outputs, because selecting the calculator function I checked the values are zero to both and creating planes nearby of these the values found are much higher than the input, even using averages or after long simulation periods. Someone who has faced similar problem could please help me? Thank in advance, Eduardo |
mass flow |
Problem with changing mass flow rate | roo | FLUENT | 3 | June 4, 2013 15:53 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 22:11 |
porous media/jump mass flow problem | Marijo | FLUENT | 0 | February 17, 2006 12:49 |
CFX-Post: problem with mass flow | Markus | CFX | 5 | February 19, 2005 18:30 |
Mass Flow Rate Conservation Problem | philippe | FLUENT | 8 | May 5, 2003 12:43 |
