Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiple phase (Mixture model)
Old   June 3, 2014, 18:55
Default Multiple phase (Mixture model)
guillaume
bayssetg is on a distinguished road
I would like to model a water tank, half of the tank is fill up of water the rest with air. I made two zones (one for the air the other one for the water) but I don't know how to say to fluent zone1 is for water and the other for air.
If someone could help me please, I will be glad
guy
bayssetg is offline   Reply With Quote
Old   July 28, 2014, 14:04
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
you can use cell zone conditions to specify this
edoan is offline   Reply With Quote
Old   September 12, 2014, 07:07
Zheng Yuheng
abruzzi is on a distinguished road
I think two steps are needed for you to specify the air zone and water zone:
1. Adapt->region to mark a zone for water(or air )
2. solution->initiallization->initiallize,and then patch the zone with water phase.
and you already got two phases in your system.
abruzzi is offline   Reply With Quote
Old   September 12, 2014, 16:43
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Suggestions are correct, but mixture model could be not good for your simulation.
Mixture model is used when secondary phase is maximum 10% mixed with the primary phase. Vof model should fit your needs.
Daniele
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   September 16, 2014, 15:04
Virendrasingh Pawar
virendra_p is on a distinguished road
Also no need to adapt...if you have created separate zones then while patching select water zone and set vf as 1(you should set your primary phase as air) and for air zone set vf as 0
virendra_p is offline   Reply With Quote
Multiphase phase Mixture model Robi FLUENT 8 October 23, 2017 08:10
Two phase mixture model me12p1006 Main CFD Forum 1 April 9, 2015 06:54
Two phase mixture model me12p1006 Fluent Multiphase 0 September 19, 2013 12:56
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Question about Mixture Model cao wei FLUENT 4 March 31, 2003 10:28
