Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Counter-current multiphase flow
Old   May 29, 2014, 18:06
Default Counter-current multiphase flow
Boris
Borsche is on a distinguished road
I have found multiple threads asking this same question, with no answer given in any of them.
Does anyone know how to set up the boundary conditions for counter current multiphase flow? Where the inlet for one phase is the outlet for the other?
I am using the Eulerian model for multiphase flow. Essentially the system is a tube where solids enter from the top and gas from the bottom. Any help would be appreciated.
Thanks
Borsche is offline   Reply With Quote
Old   October 4, 2014, 03:43
Default BC for counter current multiphase flow
Richard Lee
coolgame2004 is on a distinguished road
have you figured out it yet? I meet the same problem.
Thanks
coolgame2004 is offline   Reply With Quote
Old   October 4, 2014, 14:28
Boris
No, I haven't! I have paused working on the problem. A colleague of mine is working on the same type of problem, and is using DEM for this purpose, but I would like do use the Euler-Euler approach.
Old   October 8, 2014, 23:31
Cees Haringa
CeesH is on a distinguished road
I wouldn't mind helping, but with your current description, I don't see what the problem is. Set a velocity inlet for dispersed phase near the top, one for continuous phase near the bottom, and at least one pressure outlet somewhere.
CeesH is offline   Reply With Quote
Old   October 9, 2014, 00:56
Boris
The problem that we are having, is that we are unable to set one face to be the inlet of the dispersed phase and the outlet of the continuous phase. I cannot set the pressure outlet of one phase in the same face as the inlet of another.
Old   October 9, 2014, 01:10
Cees Haringa
Ok, so the geometry you are using is some kind of open-ended tube, in which it would be wrong to seperate the in- and outlet? I agree, that is a difficult problem, and I am not aware of any off-the-shelve solution for that. My suggestion would be to dive into user defined functions on this one, but I'm not completely sure as I have no experience with this type of geometry. You don't see any option to segregate in and outlet as with a spray dryer or so?
Old   October 9, 2014, 08:22
Default BC for Countercurrent multiphase flow
Richard Lee
I am trying to use the UDF to solve this problem. I found that the macro F_C0(cell,thread) might be helpful for solving this problem (my idea is that: at the inlet of the continuous phase, i.e. at the bottom gas inlet boundary, i hook a inlet solid boundary using DEFINE_PROFILE, which extracts the values of the cell nearby this boundary. those value includes the velocity, volume fraction etc of the solid). but to hook this macro F_C0(cell,thread), i need to compile the UDF rather than interpret it. now i have a problem to compile the UDF (i have been using the interpreted UDF before). these two days i try every best but failed~ the error is like this:
Error: open_udf_library: The system cannot find the file specified.
help me~
Old   October 9, 2014, 08:30
Richard Lee
Thanks for you advice!
these days i do try to use the UDF to solve this problem. my idea is to use the F_C0(cell,thread) macro, but i haven't obtained useful results. i will get on with it.
Old   November 11, 2014, 09:36
Rudi
rudofly is on a distinguished road
Hi!
How is your progress on UDFs? I wonder why solids need to be able to exit the domain? What you want to simulate sounds a lot like a fluidized bed to me.
Best regards,
Rudi
rudofly is offline   Reply With Quote
Old   August 31, 2015, 02:26
Default BC for countercurrent multiphase flow
Richard Lee
Originally Posted by rudofly View Post
Hi!
Best regards,
Rudi
Hi~
I 'am still get on with it.
you are right, the purpose of using such (inlet+outlet) boundary conditions is to model a gas-solid countercurrent FB.
Sincerely,
Richard
Old   December 6, 2015, 06:16
Ravi Agrawal
abc197 is on a distinguished road
Hi guys,
Have you been able to figure this out? I have been working on the same problem. How about this approach- At the inlet of continuous phase, using mass flow rate of dispersed phase in -ve direction. This way, both phases are in opposite directions. Temperature values can be mentioned at continuous phase outlet, which is also the inlet for dispersed phase. Can this work? I would really welcome any other approach that might have worked in this problem.
abc197 is offline   Reply With Quote
mesh size in Eulerian multiphase flow - liquid/solid mixture microfin FLUENT 4 December 23, 2016 14:55
dilute gravity current at very flow base doronzo FLUENT 0 October 5, 2011 16:38
Multiphase Flow Pavlos FLUENT 0 August 8, 2011 09:43
Multiphase flow in atomiser santhosh1987 FLUENT 0 May 12, 2011 05:26
Multiphase flow & porous media Hisham OpenFOAM 3 April 10, 2011 08:04
