Setting up heat transfer beetween wall heated zone and flow channel zone in Fluent |
May 25, 2014, 06:08 |
Tafany Muller
Hi everyone,
I am working on a CFD simulation of a subcooled boiling in a heated Channel. The heat is applied to the heated element using a UDF. The heated element and the flow channel are seperated by a clad. the heat transfer between this last one and the heated element is working. The problem which I have is that the heat does not transfer from the clad to the flow zone. If someone can help me to solve this problem I will be greatful. Thank you in advance. Tafa |
boilig with rpi model, fluent, heat and mass transfer, heat exchange, rpi model |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 10:28 |
Split boundary zone in FLUENT for mass flow | eishinsnsayshin | FLUENT | 1 | January 18, 2013 14:43 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
