May 24, 2014, 11:28 |
Porous Boundary Condition
Spandan Pratyush
I am facing a problem in applying porous boundary conditions in a Diesel Particulate Filter. Geometry is such that there are two adjacent channels with porous separation in between, with only one end open on one side, while the other is plugged. So, one channel is used a s inlet for air and soot mixture, which comes out from the opposite. Since, the mixture passes through the porous wall, so soot gets trapped here forming a monolayer and then subsequent layers, continuously reducing the porosity, with each iteration.
I am using Euler-Langrangian scheme for calculation where particles are being tracked, so how do I apply porous boundary condition on substrate wall in fluent? Moreover, how do I vary the porosity with each iteration based on the mathematical setup in the paper below? http://www.sciencedirect.com/science...09250909004473 |
mixed inflow/outflow downstream boundary condition question | peob | OpenFOAM Running, Solving & CFD | 3 | February 3, 2017 11:54 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Velocity profile boundary condition | Tuca | FLOW-3D | 1 | April 23, 2013 13:02 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 12:32 |
