Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
DDPM (dem) model specifying collisions with boundaries
Like Tree5Likes
Old   April 1, 2016, 03:39
Default DEM Tutorials
  #21
Amna
Amna is on a distinguished road
hello Amir
could you please send DEM helping material on this id : amnaamanat73@gmail.com
Actually i m simulating a fluidized bed using DDPM model with DEM collisions & i dont know how to set the normal or tangential collision parameters in DEM tab.
it'll be really nice of you if you let me know this .
thankx
Amna is offline   Reply With Quote
Old   April 3, 2016, 11:41
Rupesh Verma
roopesh99 is on a distinguished road
Originally Posted by Amir1 View Post
Hi, Just sent you some papers you asked.
Good Luck, Amir
Hi Amir,
I am using ANSYS Fluent DDPM-DEM. Can you share the idea/papers about setting the value spring constant and damping etc.
roopesh99 is offline   Reply With Quote
Old   April 10, 2016, 22:07
Amir
Amir1 is on a distinguished road
Just sent you some files.
GL, Amir
Amir1 is offline   Reply With Quote
Old   August 14, 2016, 18:06
Question DDPM-DEM to simulate transient flow in a downer fluidized bed column
  #24
Dawood Al-Mosuli is on a distinguished road
Hello All,
I am a beginner to use ANSYS Fluent DDPM-DEM to simulate transient flow in a downer fluidized bed column. I faced three main problems:
1- Because the DEM time step (s) 5×10−6 which i believe that it is the same as the particle step size is recommended to be very small then the solution is so time consuming. It takes one day for each 0.25 sec with a very good computer.
Does anybody have an idea to increase solution speed?
2- I suppose to have a continuous particle injection through the upper surface, but whatever I changed with the parcel release method, I got separate injections of particles. What to do to have a continuous solid flow?
3- Is it normal with transient flow to have highly oscillating residuals even if the simulation results were physically accepted?
Thank you
Dawood
Dawood Al-Mosuli is offline   Reply With Quote
Old   February 16, 2017, 21:48
David Li
Liguoguo is on a distinguished road
hello Amir
could you please send DEM helping material on my email address : wangtong218@gmail.com?
Now I'm working on the particle fouling in metal foam using DDPM + DEM.
thanks
Liguoguo is offline   Reply With Quote
Old   March 11, 2017, 08:11
mohamed
medo-elbob is on a distinguished road
hello every one
I'm trying to model multi-phase flow (water - oil) in corrugated plat separator using multi-phase eulerian model and dence Discrete Phase model + stochastic collision +coalescence model. I got problem modeling oil droplet behavior.
My set up:
1) multi-phase eulerian model active dense Discrete Phase model (all others setting are default here)
2) Transition k-kl-epsilon model
3) Discrete phase model: unsteady particles tracking, interaction with continuous phase, implicit tracking, no accuracy control (all others setting are default here)
4) check in physical model stochastic collision +coalescence model all others setting are default here)
5) There is one cell zone: operating pressure=101325pa, gravity on, operating density=1100kg/m3
6) Boundaries: one velocity inlet, 1 pressure outlets, all others are walls
7) All solution controls are default, time step size 1 s
i have message reversed flow pressure outlet
So my question to you how to set up oil- water gravity separation problem properly, what models should i use?
pleas help me
medo-elbob is offline   Reply With Quote
Old   March 24, 2017, 07:42
Naval V.Koralkar
nkidol08 is on a distinguished road
Hello Amir
Can you please send me the papers on CFD-DEM simulations. My email id is koralkar.naval@gmail.com
nkidol08 is offline   Reply With Quote
Old   March 28, 2017, 01:50
Naval V.Koralkar
Could you please mail me with those papers at koralkar.naval@gmail.com. Thank you.
Old   May 1, 2017, 05:30
Default Dpm
  #29
sewgolam is on a distinguished road
Hallo,
I'm doing my thesis currently an working on solar reactor.
I have a simple geometry of rectangular and i simulate am single phase flow and mixture flow in a laminar flow.
Now i want to inject particle in my flow but do not have idea how to do it.
I want to lagrangian-Eulerian model to track particle in my fluid.
Can anyone help my and coud you give me step wise how to do it because im totally new in fluent.
thank you
sewgolam is offline   Reply With Quote
Old   June 8, 2017, 05:41
Jay Yin is on a distinguished road
Good Luck, Amir
Hi, I'm also studying ddpm. Can you share the papers with me? thanks! ywj123450@gmai.com
Jay Yin is offline   Reply With Quote
Old   July 18, 2018, 07:13
Default Dem
  #31
Saxony Anhalt
umairjamil is on a distinguished road
Just sent you some useful papers. As I mentioned these articles gives you whats behind these numbers and what models you should select with which valuse.
Best, Amir
Dear Amir,
Is it possible you could also fwd me the papers you have mentioned. Thank you very much in advance.
Regards,
Umair
umairjamil is offline   Reply With Quote
Old   November 24, 2020, 05:03
Smile
  #32
Robin Scherbatsky is on a distinguished road
Originally Posted by mroue View Post
Dear Amir,
Could you also please share the papers with me at mroue@hotmail.co.uk. Thank you
Dear Amir,
I have this difficulty in this respect, so could you also please share the papers with me at email[LDN18801161129@163.com].
Thank you.
Robin Scherbatsky is offline   Reply With Quote
Old   January 9, 2024, 07:20
Post Eulerian-DPM modelling with DEM collisions
  #33
Sharang18 is on a distinguished road
Dear Amir,
Could you also please share the papers with me at sharangdeshmukh.222th018@nitk.edu.in Thank you
Sharang18 is offline   Reply With Quote
dem, dpm, fluent 14.5
Is it possible to model natural convection in a 2D horizontal model in fluent caitoc FLUENT 1 May 5, 2014 14:32
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Eulerian model with DDPM Lucaaa FLUENT 2 February 20, 2013 09:56
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 21:51
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 11:15
