Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
VOF: Negative Velocity Inlet
Old   May 7, 2014, 11:42
Default VOF: Negative Velocity Inlet
Jan Galijasevic
Jan90 is on a distinguished road
I am simulating a closed tank which is completely filled with oil and water (VOF). This mixture is being produced by a well in the center. Since it is not possible to specify a volume flow rate as a boundary condition, I am using a negative velocity inlet. As you know, I have to specify the volume fraction of the secondary phase at a velocity inlet.
Is it possible to avoid this? I want to produce both fluids (at later point in time) to see an increase in volume fraction at the outflow boundary over time.
Please help me, because I am struggling with this problem a long time and I can"t use an outflow or pressure outlet boundary, because the only information given is the production/flow rate of the pump.
Thanks in advance.
Jan90 is offline   Reply With Quote
VOF Volume fraction in Velocity inlet aruelle FLUENT 2 May 10, 2024 11:17
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Setting Density for Velocity Inlet Face arkie87 FLUENT 0 November 7, 2012 16:15
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 04:01
problem defining inlet velocity direction salman FLUENT 3 January 3, 2007 12:34
