Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Which multiphase flow to solve this problem?
Old   April 30, 2014, 08:39
Default Which multiphase flow to solve this problem?
mariam.sara is on a distinguished road
Hello I am tried to solve nanofluid problem with base fluid water and Al2O3 as particles flowing into a pipe I want to predict heat transfer coefficient and temperature distribution at the pipe wall which multiphase flow model is better to solve my problem?
mariam.sara is offline   Reply With Quote
Old   April 30, 2014, 10:58
Camilo Costa
camilo_costa is on a distinguished road
I think your problem is not difficult to resolve!! Choose a eulerian model and set the second fluid as a granular!!!
camilo_costa is offline   Reply With Quote
Old   April 30, 2014, 11:12
Thanks a lot Costa for the answer. I need to ask I have solid particles of Al2O3 can fluent treat it as another phase? I took your advise about granular it need the granular viscosity the default value is 1e-05 and granular bulk viscosity (which i do not know?) how much i set its value?
Old   May 4, 2014, 12:04
Camilo Costa
Yes Al2O3 will be treat as another phase. You have in fluent two model for modeling dispersed solids particles:
1ª Eulerian model (granular)
2ª Mixture model (granular)
If you have much interation (contact) between the solid particles and the volume fraction is high i dont remeber but i think the Eurelian is more apropriate. In another case use Mixture model. Look this paper:
http://mech.vub.ac.be/thermodynamics...ryk_Widera.pdf
about choosing Turbulence model for multiphase flow problem. Near FLUENT 5 April 11, 2019 05:24
SetFieldsDict file problem with 3D multiphase flow jeff_87 OpenFOAM Pre-Processing 11 May 3, 2013 07:20
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 17:10
problem with multiphase flow sri FLUENT 4 July 24, 2007 07:56
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 17:52
