Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Particle ignition problems
Old   April 28, 2014, 20:26
Default Particle ignition problems
Joakim M. Johansen
jmjohansen is on a distinguished road
Dear forum,
I am modeling particle combustion in power stations, swirl stabilized suspensionfiring. But I am having trouble establishing particle ignition.
My approach has (roughly) been:
  1. Establish cold flow - no particle injection
  2. patch a high temperature throughout the domain
  3. run 1 iteration with the DPM model enabled, enusring enough tries for all particles to evaporate or escape, and with the underrelaxation factor for the discrete phase set to 1. This should genreate all the gaseous source terms needed to maintain high gas phase temperature.
But this is where I run into problems. When I run the single iteration with the particles, the domain cools down below devolatilization temperature, and the process stops.
Any tips or tricks are welcome.
I am using species transport with the eddy-dissipitation mech.
Devolatilization rate set to single first order, with default kinetics.
In the ieger to obtain ignition, I have underestimated the particle diameter.
Best regards,
Joakim
jmjohansen is offline   Reply With Quote
biomass, combustion, dpm, ignition, multiphase
DPM particle time step amos FLUENT 1 January 4, 2020 09:46
droplet separation off a particle in turbulent stream anonymous_89 Main CFD Forum 0 August 22, 2013 14:40
Particle Tracking for ion Jun CFX 2 August 31, 2010 09:19
Particle Trajectory calculation yueroo FLUENT 2 July 13, 2009 14:32
Particle Trajectory calculation when particle hit yueroo FLUENT 2 February 28, 2001 05:26
