August 26, 2015, 15:36 |
#21 |
Ashley Byers
Rep Power: 11 |
Hey there
I am doing a 2-d axi-symmetric case with water in a capillary. Water is going much, much farther in the capillary than the analytical solution. It is not even close. -My mesh is on the +x-axis, gravity in the -x-axis. -Using VOF model, explicit scheme -Piso coupling -Surface Tension 0.07 N/m -Contact angle 70 degrees -Pipe radius of 0.3 mm -Pressure Inlet and pressure outlet are gauge 0 This should go about 16 mm, but it does not. Does anyone have any idea why? Also, what is an acceptable residual for this problem? Thanks in advance for any help. Last edited by AshleyB; August 27, 2015 at 12:29. |
January 15, 2017, 22:47 |
#22 |
Peter Parker
Rep Power: 10 |
I simulate two immiscible fluid, a channel fow with primary phase is water, there is air cavity with air bubble as secondary phase
VOF model, CSF, Geo-reconstruct solver; velocity inlet, pressure outlet BCs; surface tension force 0.072 N/m But I get weird velocity vector at the interface (see attached picture). Is there anyone know how to fix this? Thanks in advanced Attachment 53209 Attachment 53210 Last edited by letsroll; February 6, 2017 at 20:43. |
February 2, 2018, 13:53 |
#23 |
Hardy
Rep Power: 8 |
Hello
I am modeling horizontal placed rectangular open microchannel with height, width, and length of 2 , 15, and 100 micrometers. The mesh is hexahedral mesh with all quadrilateral. In General section choose pressure-based and transient time. By marking absolute velocity. In setup use VOF model, which includes open channel flow, coupled level set method and Implicit body forces. Taking air as a primary phase and water as secondary phase. In which interaction include surface tension between water and air of 0.0735 mN/mM. I am putting drop of water in contact with open microchannel. In boundary condition, inlet(water) is pressure inlet with volume fraction 1. outlet (mixture of water and air) is pressure outlet with 0 volume fraction. Atmospheric(air) as pressure outlet. In all this boundary condition I select open channel flow in the multi-phase option with free surface level 2 micrometer. Also, choosing operating density by default. By considering mixture for Wall Zone with stationary wall, no slip condition with wall adhesion between water and air of 90 degree. Solution method, scheme - PISO, gradient - least square cell based, pressure - presto, Momentum - quick, Volume frcation - Implicit scheme. Solution Initialization, Compute from - Inlet and initialize it. In patch select water and variable volume fraction with value 1 and zone to patch is liquid. Run calculation with time step 1.0e+6 microsecond with 1000 iteration. Please, help me if anything wrong in the above explanation of model. In this, I want to find out how much time fluid takes to travel through the end of channel with the effect of capillary force. But, I didn't got the correct results. So. I hope somebody help me on this. Thank you in advance. |
February 2, 2018, 13:54 |
#24 |
Hardy
Rep Power: 8 |
Hello
I am modeling horizontal placed rectangular open microchannel with height, width, and length of 2 , 15, and 100 micrometers. The mesh is hexahedral mesh with all quadrilateral. In General section choose pressure-based and transient time. By marking absolute velocity. In setup use VOF model, which includes open channel flow, coupled level set method and Implicit body forces. Taking air as a primary phase and water as secondary phase. In which interaction include surface tension between water and air of 0.0735 mN/mM. I am putting drop of water in contact with open microchannel. In boundary condition, inlet(water) is pressure inlet with volume fraction 1. outlet (mixture of water and air) is pressure outlet with 0 volume fraction. Atmospheric(air) as pressure outlet. In all this boundary condition I select open channel flow in the multi-phase option with free surface level 2 micrometer. Also, choosing operating density by default. By considering mixture for Wall Zone with stationary wall, no slip condition with wall adhesion between water and air of 90 degree. Solution method, scheme - PISO, gradient - least square cell based, pressure - presto, Momentum - quick, Volume frcation - Implicit scheme. Solution Initialization, Compute from - Inlet and initialize it. In patch select water and variable volume fraction with value 1 and zone to patch is liquid. Run calculation with time step 1.0e+6 microsecond with 1000 iteration. Please, help me if anything wrong in the above explanation of model. In this, I want to find out how much time fluid takes to travel through the end of channel with the effect of capillary force. But, I didn't got the correct results. So. I hope somebody help me on this. Thank you in advance. patelhardy52 is online now Add to patelhardy52's Reputation Report Post |
March 12, 2018, 06:55 |
#25 |
Ani
Rep Power: 9 |
Sorry to revive an old thread and thanks @Stiboo for the explanation.
A general question, after the VOF run, the velocity that is obtained, is that a velocity of the mixture of phase-1 (air) and phase-2 (water)? I want to compare the secondary phase (in my case, water) velocity with the results from experimental measurements, but all I get is the "mixture" velocity. Is there a way to retrieve a "phase velocity"? |
June 19, 2018, 05:33 |
#26 | |
Akashdeep Gangrade
Rep Power: 8 |
first i performed 3000 iteration than 3000 more two times during second time it rises more than previous one and at last it rises upto the top level any help is deeply required if someone doing same i can share my wbj file |
June 19, 2018, 07:46 |
#27 | |
Akashdeep Gangrade
Rep Power: 8 |
June 23, 2020, 13:47 |
#28 |
Faiz
Rep Power: 6 |
sorry to revive this old thread, but has anyone figured out how to fix this? The capillary height in the simulation has far passed the analytical solution and is still rising.
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 18:02 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 06:36 |
Open channel flow simulation using VOF | rsaha | FLUENT | 5 | April 10, 2016 18:28 |
How to simulate three-phase flow in VOF? | adam14qin | FLUENT | 0 | July 28, 2012 05:02 |
Air-water flow (VoF). Need help :( | Luke1984 | FLUENT | 6 | October 19, 2009 10:59 |
