two-phase flow with a single phase simulation |
October 28, 2013, 02:42 |
Lawrence
Hello everyone,
I tried to do a simulation of heat pipe which exposed to a hot air at the heat pipe external wall. The flow inside the heat pipe is a two-phase flow condition (water-vapour) and the heat pipe external surface is a single phase flow (only expose to air) I used VOF model +UDF, set vapour as primary fluid, set water and air as secondary fluids. Before the simulation begins, I patched the heat pipe external volume with air and water inside the heat pipe. I noticed that external volume truned back to vapour phase after the simulation completed. I wish to know how do you setup this kind scenario in FLUENT? Thank you. Regards Lawrence |
multi phase, single phase, vof model |
PEM fuel cell simulation | pchoopanya | Mesh Generation & Pre-Processing | 1 | February 29, 2016 23:56 |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 07:59 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Two-phase/ Single phase mix flow | Reza | Main CFD Forum | 1 | August 6, 2003 06:36 |
