Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Plotting Rosin-Rammler Distribution
Old   October 24, 2013, 06:31
Default Plotting Rosin-Rammler Distribution
lucas s
LoUcAsss is on a distinguished road
Hi everybody,
I am trying to plot the diameter distribution at the inlet which is injected from the inlet.
I tried to plot an histogram of the diameter distribution using Reports-Discrete Phase-Sample and then Histrogram, but it didn't work.
Can anyone help me?
Thanks,
Lucas
LoUcAsss is offline   Reply With Quote
Old   October 10, 2016, 06:56
Kasper is on a distinguished road
I have the same issue. Have you solved it in the meantime?
I would like to know exactly what has been injected.
Kasper is offline   Reply With Quote
Old   November 1, 2016, 03:11
hwet is on a distinguished road
did you sample and save the sample file of the dpm first?
hwet is offline   Reply With Quote
Old   November 2, 2016, 07:07
Thanks, yes, but a sample at the inlet seems empty.
So the only way to know what has been injected is to add trapped, released... fractions on outlets and walls as far as I've found.
But what is injected numerically seems to be always one particle per diameter per node. The R-R distribution is probably used for weighting (e.g. impact on the fluid in case of two-way interaction). But I didn't find a way to easily visualize it in the histogram.
diameter distribution, dpm in fluent, rosin-rammler
Problem with Rosin Rammler Chrisi1984 OpenFOAM Pre-Processing 1 February 24, 2021 12:53
Rosin Rammler Distribution mystix OpenFOAM Running, Solving & CFD 10 February 11, 2021 06:23
rossin rammler distribution in DPM hendar_k FLUENT 0 May 23, 2011 04:18
Rosin Rammler Distribution AndiG FLUENT 1 March 7, 2007 11:56
DPM-Rosin Rammler distribution -CV probleme olivier FLUENT 2 August 8, 2001 13:13
