Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Difference between different multiphase models in Fluent??
Old   September 9, 2013, 15:05
Question Difference between different multiphase models in Fluent??
Anandanarayanan's Avatar
Anandanarayanan R
Anandanarayanan is on a distinguished road
Hi friendz...I'm little bit confused with the different multiphase models in Fluent...I would also like to know, to which multiphase application i can use the specific model...additional information's are appreciable.
Anandanarayanan is offline   Reply With Quote
Old   October 2, 2013, 07:41
OJ
oj.bulmer will become famous soon enough
If you post a question this broad, I would be surprised if you got any elaborate answers. Have you referred the FLUENT documentation? There is plenty of information in there. Additionally, you can also download the presentation slides on this from ANSYS portal.
OJ
oj.bulmer is offline   Reply With Quote
Old   February 9, 2014, 01:12
Default Eulerian
mostafa
mostafa_zeynalabedini is on a distinguished road
hello all
I have two question about Eulerian-Eulerian multiphase model in FLUENT. 1-Is this model the same as Two-fluid model by Ishii? If yes why it does not have any void fraction advection equation?
It has two set of conservation equation for each phase but a new unknown variable as void fraction (assume that we have two phase and their summation is equal to one, so there is one unknown void fraction). So two solve this set of equation another equation is required, and there is no other equation in FLUENT help document. So how does the Eulerian model work?
2-I searched in two-phase two-fluid model literature and there is mostly no solution of two-phase two-fluid model in 2dimension for stratified or slug flow. Because the interface position as one boundary (moving boundary) is not clear meanwhile the solution. So how does Eulerian model solve problems in 2 or 3dimension?????
mostafa_zeynalabedini is offline   Reply With Quote
Old   January 3, 2023, 09:27
Naveen
nvnkush is on a distinguished road
https://www.afs.enea.it/project/nept...th/node293.htm
nvnkush is offline   Reply With Quote
fluent, multiphase modelling
Using real gas models in Fluent neville FLUENT 1 June 5, 2012 06:54
Multiphase flow modeling: CFX or FLUENT? Paul Main CFD Forum 8 January 24, 2012 10:25
fluent multiphase modelling thinktank FLUENT 0 November 28, 2009 14:41
FDS vs Fluent, what's the difference on LES? Jim FLUENT 0 August 12, 2006 16:32
implement user's models in Fluent Steve FLUENT 1 January 14, 2003 18:22
