August 12, 2013, 07:26 |
VOF Problem
Smaras
Rep Power: 14 |
Hello all,
Well i am trying to do VOF with three phases i.e. slag, metal with oxygen impingement. Would like to know when initializing its asking for the oxygen and slag volume Fraction. I don't have any idea....i have use two phase with water and air having air fraction as 1 while water fraction as zero. in my previous simulations. But this i am totally confused. Would be thankful for your help. Regards, Smaras |
August 12, 2013, 15:31 |
Hi Smaras,
You need to properly patch the regions of different fluid mediums and initialize them. Before starting with the computation you can plot the volume of fraction and check if correctly display the various fluid regions. Hope this helps. |
August 27, 2013, 07:36 |
#3 | |
Smaras
Rep Power: 14 |
Well i tried patching them but still only getting the plane like phases at the interface of slag and oxygen in solution initialization and then patching it. Still not completely filled. Is there any way to do it? Would be thankful. Regards, Smaras |
vof model |
a problem of incompressible two phases(water and gas) with VOF Method | zhangweisnoopy | Main CFD Forum | 9 | August 12, 2011 09:25 |
Two-phase VOF problem | scott copland | FLUENT | 3 | March 15, 2007 08:25 |
Problem with VOF open channel modelling | Biswanath Mahato | FLUENT | 1 | September 14, 2006 05:20 |
A Problem with setting the time step in VOF model | Le | FLUENT | 2 | July 20, 2006 23:00 |
problem with VOF. | Marc | FLUENT | 1 | June 5, 2002 09:17 |
