Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Convergence problems with Wet Steam Model
Old   August 12, 2013, 00:51
Default Convergence problems with Wet Steam Model
eromon84 is on a distinguished road
I am trying to simulate a turbine model using the Wet steam fluent model.
I am having numerous problems with the boundary conditions I specify.
I have very high inlet pressures.
Operating Pressure set to 0.
Pressure inlet:
Supersonic / initial gauge pressure : 31 77589 Pa ( 31.8 bar )
Gauge Pressure : 30 00000 Pa ( 30 bar )
Total temperature: 570 K
Pressure Outlet:
Gauge Pressure: 1.37 bar
Total backflow Temperature: 394.155 K
when I try to initialize the solution I get the following errors in the respective fields.
x velocity: -1.#IND
y velocity: -1.#IND
Temperature: -1.#IND
I tried varying the gauge pressure at inlet and noticed that these errors only occur when my gauge pressure goes above 4.3 bar or so. Can anyone help me understand what is going wrong here? My AMG also diverges like crazy even when I do try any values below 4bar.
my inlet flow is meant to be subsonic and transition to supersonic within the nozzle. Steam should be superheated at inlet and I wanted the analysis was meant to be looking at the formation of droplets across the turbine.
eromon84 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Convergence issue in SST for Porous model Raj CFX 0 May 2, 2008 03:43
Convergence Problems Carlos FLUENT 0 March 12, 2007 03:44
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
