Inclined cylinder, countercurrent-multiphase flow |
July 23, 2013, 12:46 |
Ravi Agrawal
Rep Power: 13 |
Hi, I am working on a problem with countercurrent multiphase flow in an inclined cylinder.(Using air and sand). Sand enters from elevated side in a way that interface line makes 90 degree angle at centre of the circular inlet section. Both air and sand have constant mass flow rates as their respective inlet conditions and other properties.
In figure attached, face 5 is the interface. Sand is below this face and air on above. So far both inner circular face and arc face are disconnected. What more needs to be done here(except meshing,inclination and zone assignement). OR I shouldnt make sand zone at all? If its OK here then how to active those interfaces. |
July 25, 2013, 14:55 |
Ravi Agrawal
Rep Power: 13 |
Please check my settings in VOF model :
unsteady, implicit, implicit body force,none is selected in phase interaction. It is a counter current flow, so air inlet is sand outlet and vice-versa. I know the inlet mass flow rates for both. Air-inlet and sand-inlet are at two opposite sides of cylinder, but sand outflow and air outflow rate are also to be specified at respectively both the sides, which I dont know at priori. I have initialized it using 'compute from all zones'. Do I have to do patching for sand phase zone. Why is it important to do? |
July 26, 2013, 01:13 |
Maxime Perelli
Rep Power: 41 |
I would suggest you to check this tutorial: http://aerojet.engr.ucdavis.edu/flue...tg/node255.htm
You aren't suppose to set the vof for pressure outlet for instance. But you need this set up for inlet. In your case, if you splitted your cylinder with your "interface", then your cylinder caps are also splitted. One will be used for sand and the other for air. That means you have 2 inlets BC and 2 outlets BC. If you also defined 2 separated fluid domains, then you patch them for initialization: At t=0, you have sand below your interface and air above
In memory of my friend Hervé: CFD engineer & freerider |
July 26, 2013, 15:17 |
Ravi Agrawal
Rep Power: 13 |
I splitted it as there is only one face which solver considered as interior. Cylinder caps are splitted and I have separate inlets and outlets for air and sand at opposite ends. (I defined them as two different fluid domains)
In image I have shown only inlets, outlets and interface for clarity. Air flows from left to right and sand, right to left. Air starts flowing above while sand, below the interface at t=0. I used mass flow inlets for inlets and pressure outlets for outlets. I can specify the air and sand flow rates at their respective inlets, but at the same respective locations, sand and air flow rates are also asked to specify, which are unknown. Back FLow temperature values are asked with pressure outlet conditions, which I am not sure about. Should I use outflow conditions then. I am looking at the tutorial, pressure outlet is used there too. I had another confusion on inclination. Will it be taken into account bu just specifying gravity components or direction vectors needs to be changed at inlets. Regards. |
July 31, 2013, 00:56 |
Maxime Perelli
Rep Power: 41 |
i didn't understand
July 31, 2013, 01:49 |
Ravi Agrawal
Rep Power: 13 |
I know the inlet mass flow rates or velocities for air and sand. At Air-inlet, for each phase it asks for mass flow rate, for air-phase I can specify, but for sand phase, I have nothing to specify, sand inlet is on opposite side, below the interface. Similarly, at solid inlet, I cant specify flow rate for air.
July 31, 2013, 02:00 |
Maxime Perelli
Rep Power: 41 |
ok, I see.
I am now completely out of my skills. Maybe you should consider working with DPM instead of VOF (but I don't have any experience)
July 31, 2013, 02:12 |
#8 | |
Ravi Agrawal
Rep Power: 13 |
Regards. |
July 31, 2013, 03:01 |
#9 |
Ravi Agrawal
Rep Power: 13 |
Actually this problem is almost same as this one, with a simplification that there is no small cylinder.
http://www.cfd-online.com/Forums/ans...ull-fluid.html |
countercurrent flow, fluent, gambit, multiphase |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
[GAMBIT] Inclined cylinder, countercurrent-multiphase flow | abc197 | ANSYS Meshing & Geometry | 10 | July 25, 2013 14:56 |
Flow over a cylinder | Anna | Main CFD Forum | 9 | March 24, 2006 14:32 |
Flow around a cylinder at subcritical regime. | yousef | FLUENT | 0 | March 18, 2006 09:18 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
