Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
where is Reference Level
Old   June 5, 2013, 11:18
Default where is Reference Level
FHydro
flow_CH is on a distinguished road
Hello.
I want to model a free surface channel.
i am using "Open channel flow" option in fluent but when i am starting the solver and its done there is no any fluid into the model (there is just air).
my question is: where is the reference level in defining pressure inlet and pressure outlet of channel. please see attached images
thanks
flow_CH is offline   Reply With Quote
Old   June 5, 2013, 11:51
OJ
oj.bulmer will become famous soon enough
Probably you haven't patched the volume fractions of water and air properly. Have a look at the VOF tutorail in FLUENT
OJ
oj.bulmer is offline   Reply With Quote
Old   June 5, 2013, 12:11
FHydro
OJ
thanks for your reply.
i read all fluent user guide but i don't understand what the patch is? what parameters i should define in patch for open channel flows.
I think my problem is in reference level.
Old   June 6, 2013, 07:44
OJ
You need to mark the registers where the fluid exists, and during initialization, set the value for volume fraction for the registers as 1. It's only then that you will have two fluids with volume fractions 1 in different regions, separated by the interface.
OJ
Old   June 6, 2013, 10:29
FHydro
i know that. my question is: where is reference level in defining free surface and bottom of channel in OPEN CHANNEL FLOW option.
Old   June 6, 2013, 11:58
OJ
Well the reference level should be any arbitrary point, probably determined by the origin of your geometry. Just make sure that you give appropriate signs of the levels such that:
"free surface level" - "bottom level" = height of open channel flow
Does this help?
OJ
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 05:28
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 01:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
