Home > Forums > Software User Forums > FLOW-3D
when I use multi block the condition of stability can not be fulfilled
Old   February 10, 2012, 07:28
Default when I use multi block the condition of stability can not be fulfilled
www.manvatoo.com
mostafa_khan is on a distinguished road
The run with :2 block(multi block) . time :49 & 50s ===>>> we haven’t the condition of stability
The run with: one block. time :49 & 50s ===>>>we have the condition of stability
Hello
Im working on flip bucket.
As you illustrated in the pictures, when I use multi block the condition of stability can not be fulfilled, but in one block im able to reach the condition of stability.
As you know,one block simulation is time consumption
I want to know there is away to reach the condition of stability by using multi-block?
I want to know where I made mistake.i wonder if my friends could possibly make it crystal clear?
Best regards.
mostafa_khan is offline   Reply With Quote
Old   February 10, 2012, 13:12
www.manvatoo.com
new run with new meshing
3block-linked :
there is that problem
details:
block N.1 : cell size=1 cm
block N.2(on flip bucket) : cell size= 0.6 cm
block N.3 : cell size=1 cm
t:60s
Old   April 19, 2012, 13:17
Jeff Burnham
JBurnham is on a distinguished road
The cells should be even multiples of those in the adjacent block. That is, your flip-bucket block should have cells that are 0.5 units long (cubes are best), not 0.6. FLOW-3D interpolates results between mesh blocks; if the cell grid lines don't line up exactly, then interpolation leads to momentum diffusion and stability difficulties (pressure solver).
JBurnham is offline   Reply With Quote
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 09:20
stability condition for 4th order of CD qunwuhe@hotmail.com Main CFD Forum 1 April 20, 2008 18:35
Stability Condition for Immersed Boundary Method Dave Rudolf Main CFD Forum 0 February 6, 2007 00:36
On LBB stability condition Yang Cao Main CFD Forum 1 June 21, 2006 07:10
stability condition manfred krueger Main CFD Forum 2 March 8, 2001 14:20
