Home > Forums > Software User Forums > FLOW-3D
Possible to model multi-phase (more than 2) flow?
Old   January 14, 2012, 01:48
Default Possible to model multi-phase (more than 2) flow?
wuyu
seasoul is on a distinguished road
For 2-phases, the answer is definitely yes.
But how about more than 2 phases? For example,
oil and water mixing in a tank filled with air. Or even four phases, let us say two types of oil and water mixing in a tank filled with air?
seasoul is offline   Reply With Quote
Old   January 17, 2012, 15:56
Jeff Burnham
JBurnham is on a distinguished road
Yes, there are several ways to model more than two fluids/phases.
1. water & oil mixing in tank w/ air: use 1-fluid, free surface, with density evaluation physics and specify RHOF and MU1 as density and viscosity of water, RHOFS and MUS as density and viscosity of oil (specify in prepin file under namelist PROPS). Use initial fluid regions to specify initial locations of oil and water, and designate them as such via the initial fluid region density (RHOF to RHOFS sets the mixture ratio). The air will have uniform pressure, although it can apply a wind shear to the surface if it is blowing (specify 'Wind' physics in v10, see User Manual for how-to in earlier versions).
2. Water, air, and water vapor: search on the Flow Science website for 'non-condensible gas' for a tech note and example.
3. Water and any dispersed phase (sediment, air bubbles, etc.): use the drift-flux model with density evaluation. Search the website for tech notes.
4. Two types of oil and water and air (four phases): not possible without code customization.
JBurnham is offline   Reply With Quote
Old   January 24, 2012, 22:26
wuyu
Thanks, JBurnham.
Can I use two fluid and density evaluation? That is one fluid for gas (defined by flow rate, because the volume and pressure are both increasing, thus cannot be treated as void). Another fluid for the other two phases: oil and water, differentiated by density evaluation?
Old   January 25, 2012, 05:18
wuyu
Originally Posted by seasoul View Post
Thanks, JBurnham.
Tried but to find it is not possible. Thinking of an alternative way.
Help: apply B.C. in my granular flow model ? Derek Jing FLUENT 1 January 8, 2020 22:38
Discrete phase or two phase model in Fluent? andrea panizza FLUENT 14 September 6, 2015 17:18
Eul-Eul flow, k-e-kp-ep-Theta Turbulence model us FLUENT 5 April 5, 2011 03:29
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
