July 27, 2011, 03:32 |
surface profile
navid maroofi
Rep Power: 15 |
I am studing about self aeration on open channels with Flow-3d softeware.I want to ask a problem about surface profile. I solve one geometry of slope with 15 degree and q=1m^3/s with ks=.001 with step by step method and run it with flow-3d for this problem but I cant match these result. flow-3d gives much bigger rusult. can anybody help me to find why flow-3d cant give the good result about surface profile?
July 29, 2011, 01:22 |
#2 | |
michael barkhudarov
Rep Power: 18 |
July 29, 2011, 04:34 |
navid maroofi
Rep Power: 15 |
I tried 3 types for inlet Bc. but didnt catch good result yet:
1.specified pressure with height "11.6" (m) with vent that open "0.35" (m) 2.specified velocity, u=2.64 (m/s) & w= -1.093 (m/s) ,h=11.07 3.volume flow rate, q=1 (m^3/s), x flow direction vector=1 , z flow direction vector= -0.2679 and continuative for outlet BC. The geometry has 40 (m) lenghth and 10.72 (m) height-15 degree- The normal depth is near 0.108 m with formula but with flow3d is near 0.2 m.why? Last edited by navid.maroofi; July 29, 2011 at 04:54. |
August 1, 2011, 08:08 |
Armen A. Ghirghidov
Rep Power: 17 |
Dear navid maroofi.
Try to use outflow BC. BTW 2 and 3 is not quite correct BC. Regards. |
August 1, 2011, 10:59 |
navid maroofi
Rep Power: 15 |
August 2, 2011, 05:06 |
Armen A. Ghirghidov
Rep Power: 17 |
Will roughness affect?
try to use another mesh. for example number of cells across channel are integer. regards. |
Thermocapillary free surface flow | zakifoam | OpenFOAM Running, Solving & CFD | 10 | December 12, 2016 12:44 |
Different surface incident radiation between surface and surface-shadow | Cortomaltese | FLUENT | 0 | July 16, 2011 08:00 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 02:10 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 13:56 |
Flame Surface Density. | Burn Ing | Main CFD Forum | 3 | December 5, 2004 18:12 |
