Home > Forums > Software User Forums > FLOW-3D
Two Fluid bouyant problem and mesh
Old   May 12, 2011, 07:49
Unhappy Two Fluid bouyant problem and mesh
Darío Martín Escala
DariusBic is on a distinguished road
I'm trying to simulate a problem of two layered fluids of different densities, such as Rayleigh-Taylor instability or double diffusive
My system consist in two layered fluids of different densities. (At first, without using scalar quantities with different diffusion coefficient, but I include it in the future)
When I want to simulate the Rayleigh-Taylor instability, noticed that the result varies with the number of cells that use. I tried to refine, but the result is always different.
My system is simple, just a rectangle defined between (-1, 1) for x coordinate, and (-3, 3) for y.
The first fluid is defined between (-3, 0) and the second between (0, 3).
My question is, How I can I know the proper size of cells so that the result is correct? Maybe any problem with the boundary conditions?
For this problem I use a inviscid flows and boundary conditions are continuity system for the coordinates, and wall to the x coordinate
Please any help is welcome
THANKS
DariusBic is offline   Reply With Quote
mesh, two fluids
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
