Home > Forums > Software User Forums > FLOW-3D
How to indicate velocity magnitude in tecplot with Flow-3d file?
Old   April 4, 2011, 01:47
Default How to indicate velocity magnitude in tecplot with Flow-3d file?
IS HAN
his124 is on a distinguished road
I usually use the program 'Flow-3d'.
and I want to draw more specific picture using the tecplot with Flow-3d output file.
Flow-3d makes a data as "flsgrf.dat".
so I imported "flsgrf.dat" data in tecplot.
and I used the menu "Analyze" , "calculate variables".
and calculated "velocity magnitude" and then set the Contour, iso-Surfaces.
but Velocity magnitude didn't come out
so I checked the Data sheet and figured out
at the first time there's no data on U, V, W
U, V, W were indicated as "0"
Do you know why it happened?
what can I do to come out value of the U, V, W?
please help me
his124 is offline   Reply With Quote
Old   June 27, 2011, 11:54
Smile I got it
Thai Duong
thaiduong is on a distinguished road
please help me
Please check the slide of z (k), because the coordinate maybe the solid part, there is no velocity, you should raise the z higher
thaiduong is offline   Reply With Quote
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
